Originally posted by GTS-t VSPEC
Ken,
All the lights stayed on, only 1/8 of a tank:D
See'ya:burnout:
1/8 of a tank was more than likely the prob
I assume that when the car hiccupped you put the clutch in hence the dash lights came on ?
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
bah!
Im tired. I go sleepy now. big day of meetings from 8 till 6 tommoz. need to be sharp-ish?!
thanks for cruising today team. had hot time.
(want hot action? call 0055-sex-sau)
and thanks to ken for showing me how to launch at 5,000 up a hill facing slightly sideways on friday night *mental note: dont look at Ken's car then try and race him*. I think you scared the shit out of 3/4 of the chooks at the egg-farms.
nite bitchis
Micko,
Yeah, I think the turbo will need replacing soon, then all you bitches better watch out. I just hope I don't need to brake:D
See'ya:burnout:
Yea , I will take a piece of that action. What are we talking 1/4 mile , laps of wanners , top end speed , MC day ??
Cheers
teh gtr cahnt lose
Ken
Originally posted by zanda
bah!
nite bitchis
Egg farms???
What egg farms or is this some young person thing ?
Cheers
Ken
So would a surge tank fix that problem. Would be scary if it died at 150 going around a corner:D
See'ya:burnout:
Or don't run the car under 1/3 of a tank.
Cheers
Ken
Originally posted by Neo
Night Zanda
Speaking of action guys when are we going to all go to wanneroo or somewhere? I would like to see that.
Unless your car is well set up and you have a lot of money to waste, Wanners is boring.
The average road car only lasts about 3 laps at full noise then the brakes and tyres are off.
Cheers
Ken
Collie and Wellington dam hillclimb are on the 26/27th April
Ken,
Before you do anymore:p After then I would struggle, unless you ran 2WD:p
See'ya:burnout:
Why would I run 2wd . Thats why I bought the R.
btw , I can cos I got a switch in the console. Good for ...err....warming the tyres.
Cheers
Ken
Micko,
I still will have the goods if he has no 4WD:p
Ken, I have my sleeping bag ready:D
See'ya:burnout:
Not a nice way to talk about your g/friend.
Ohh thats right , the hand doesn't answer back. Hehehe
Cheers
Ken
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
