  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Paul :Ha.... I used to be a fire warden.... the fire drills were kinda funny... We had to race around pretending the building is on fire and convice people to leave there work and follow me to avoid this pretend fire :)
Troy: Geeez thanks mate.... love you too :)
Hi everyone! How did you all pull up from the cruise?
Whens the next cruise?
We are gettin a full sscchhiicckkk VN with body kits etc. I will have to take that and beat yas all!!! LOL
Nope, definatly stickin to the GTS-X!
Ha... I was wondering when you would mention that :)
I was hoping you wouldn't notice.... Its not that my car couldn't stop it was just last minute indecision as whether or not to push the orange light on the turn.... I opted for the safer option.... I only just passed the line anyway... wasnt even worth reversing :)
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
