  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by macka
I got a better Idea
Your place you bring beer :)
Joe and Adam are both banned
Morning all...:D what a weekend that was. :D
I know why I got banned but why adam? hheheh :)
I am behaving good ATM and earning brownie points from Tanya :D
Mack you are bastard! I have to get you back on taking photo and keeping the records of everyone Drunkeness. :)
cheers
JOe
Have great day all ;)
even you macka and Paul :D
Originally posted by SHUTO-BOY
paul is driving crazy all the time on purpose, to blow up his current turbo and have a reason to get a new one
I must say I had fun in Paul's car yesterday :D
It was fun winding roads of kalamunda :) :uh-huh:
and no I can drive as good as him if I had skyline with same power and gay wing like that :) who wouldn't! :D
So that explains the brake failier on the GTS-X the arvo of the cruise. They don't like stopping.
The VN aint costin me nothin!!! Just better to drive than a leaky Corolla during the winter. I have more of a shower in that than in the actual shower itself!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
