  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Saw nizmo racing (more like :burnout: ) with Honda civic at the corner of st george's terrace and william street hahah...
Civic was reving his engine hahah :bahaha:...
Niz slowly took off then, she looked and laughed at him!
but Civic kept reving and took off with mighty front wheel spinning.
I guess other car drivers does that with skyline or maybe its skyline plus chick factor :confused:
I waved to niz but she didnt see me or she ignore me :( I was in my boss's BMW 3series...(321i or somethng) taking out for spin :) (actually taking car for servicing :P)
cheers
Joe
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
