  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha oh well joe im sure he lived - just needed to see a close up of my back end to make sure he sees the nissan badge :)
Joe u've seen my driving surely nothing shocks u still about it? haha
we dont know what the problem is but we know it aint the blow off valve. Its getting tuned shortly.
Paul i did believe them there for a while - it didnt quite add up when they told me but i assumed they would know haha thank u and ken for shedding the light.
Liz he may not talk to u like your some chick - but just make sure u double check whats being said to u to make sure its correct - not first time ive been led down the wrong path with those boys.
Joe - yeah i was listening to that ad today about driving tired kills and it says the first warning sign is when your brains tuned out - but hell my brain is always tuned out :)
If u want to see drift i shall break out the ZX :) besides if it run into curbs doesnt matter ive already bent a few bits and bobs doing that with it.
Liz by the way my above comment applies to anyone - double check do ur homework get others to double check and it'll all be good :)
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
