nah u were pretty tame when i was in the car paul - haha maybe u just value my life more or know that if your not already dead when u prang the car and i get injured my dad will finish the job on u :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Amen :)
See Paul im a good passenger i dont complain haha i just encourage :)
hahah lol ME P U S S Y? hhmmm... I want to live to see my grand son marry his dream girl!
I've learn that once you pass on your gene then you are free to do anything but until you pass your gene down the generation, you take care...
it's not me I am looking after my HONG gene :)
Originally posted by GTS-t VSPEC
Joe,
You were OK on the passenger side, I'd have died first:p
Cam, Aidwin said you screamed like a girl when I went through that gap:D
See'ya:burnout:
and woot? Passenger dies b4 driver does...
My best mate from high school died in passenger seat...:)
thanks paul - buffy the musical hmmm i'll pass my dreams sounds better.
*hugs all*
Ken I hope u didnt use a whole tissue box on stingers :)
No but the nurses uniform she was wearing caused a few problems.:uh-huh:
Cheers
Ken
Ohh and night Niz
* fatherly peck on cheek *
hehe
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
