sup psiker, damn you even going to the drags arggggggggggggh :P
anyways cool cool paul :D i will try and bust nenguns balls to get a reply from them, maybe i can find out the contact number but they in japan aren't they?
adrian :)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Finally im back
Yes the car still at the shop waiting on a quote.
Niz: i know what u mean there, my hair is fine as and it grows lieka madman up unitl just above shoulder length and then practically stops. Yeh i was one of those goons with long hair in highschool
Originally posted by Adrian_perth
do u go to UWA psikerpaul?
l8r niz, have fun at the drags tonight :D
adrian :)
hhahahahhaha ... no :P
they had a prosh day or whatever it is. they dress up and sell papers for charity. i got assailed by about 300 people asking me to buy a paper. but spent the rest of the time enjoying the hotties dressed up with really sort skirts and the like. many slaps from yolonde was had :(
Psiker
haha psikerpaul, i would have thrown some punches lol "No I don't want your damn paper for the last ****in time" POW! hehehehehehe
kyles, stay angry at troy, we wanna see him crying at nite while is whoring :D:( (jokes troy if you read back)
HURRY UP NENGUN WAKE YOUR AUSSIE LIVING IN JAPAN ASSES UP AND EMAIL ME BACK B4 I GO WORK oops did i do that in caps lock :)
adrian :P
adrian :P
get him to watch an animated disney movie or a soppy romantic move like pretty womman and he will cry!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
