  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Boostzor
And there u stand, little son of rajab fuantleroy, surrounded by the maladjusted, ever try wearing a bonnet? u should.:bahaha:
lol no reason to tell it like it is :D
hrmmmm bonnet. nah it doesnt set my eyes off :P (unless its carbon fibre :) )
Psiker
(and yes i know what bonnet u mean :( )
Psiker
Nah i dont play online. I have to be able to alt tab out. I am at work after all.
Hey how about 4NIC8 on an old hq wagon
can still alt tab just the same online :D. if u played online i could help ya finish the whole game in half an hour :) all the way thru hell
Psiker
I still gotta build up some levels and that takes time. Remember the good ol days where u could copy items with that little bug
yah back in d1 days. there are alot of hacks out for d2 now. not so many when i started playing :D but its all goodpretty much what i wouold do online is rush u all the way thru hell then do cow hell games with u :) so u gain heaps of exp very fast. ppl mainly only play online to pk or magic find now. its good casue ppl cant take ur items when they pk you
Psiker
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
    • Hello everyone, I am happy to join you.
    • Whereabouts are you, that looks exactly like Akira's old car....
