Don't worry Dan, the car has plenty of power, and there are lots of things that we can do to improve it, but Drag setup is not as simple as everyone believes. At least your over your nerves and next time you can get doen to lowering your times:D
See'ya:burnout:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
PVA...Nice...What sort of rare the sphincter of the universe is it?
Does it come from korea..
Thats what happens when ya sell ya car :D
Ok Paul your a c*nt
there i called ya
Dan Yeah its pretty tricky look at GTSTVSPEC hes done like 100 odd passes and is still shit
If i can do a 12.98 on dodgey nenkangs and 286HP so can u with a bit of practice :)
Ok Paul your a c*nt
there i called ya
AHAHAHAH!!!
Hey i thought you were running over like 300 rwhp at the wheels when you did that.... MAN I AM CRAP :-)
my 0 - 60ft was 2.8 secs... :-(.... hitting into second and car nearly goes sideway on me from too much wheelspin plus spin into third don't help much either :-(
I really did enjoy myself though!! it can be quite addictive can't it!
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
