  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
No racist slurr intended but Asians just cant drink as well as us classic aussies and brits.
Same as aboriginals, they cant produce the enzyme that breaks down alchohol as well as we can. Could have something to do with the few hundred/thousand years weve been drinking brews of all sorts.
Indians are pretty good though, they can put em away but they get messed up in the head. I reckon the true drinker just get quiet:D or maybe Gradenko is just screwed in the head :D
Originally posted by GTS-t VSPEC
Troy,
I already gave you $20 remember, Dan asked me for more:p
See'ya:burnout:
Ohhhhhh thaaaaaat extra $20 was for save the red whales fund.....:D
Yeah Troy... i tried to do hitman styles on Paul but wasn't able to as he said that he had given you $20 for lunch or sumfin... plus i was embarrased after getting ya names mixed up.... i think from all the addrenalin i was talking to fast for people to understand...always happens when i get excited and muck my words around :-) huehuehuehue;)
im back from my three hour lunchbreak :D
Paul u reckon im giggly when im pissed these girls would deafen you!! and they have sicker minds than me haha
got garlic breath - i only had a glass of vino so im cool - otheres a bit tipsy.
ive gone from unhappy bitch this morning to having too much goddamn energy and a smile on my face - think it was the expresso coffee with icecream - sugar & caffinene hit me very very hyper.
whats this with $20 and my black R33 sleeping with the fishes *slaps dan* dont u ever make threats about my R33 otherwise you'll be sleeping with the fishes!! and my services are worth a lot more the $20 :D
