haha goon - i havent heard that word in ages :D
its just one of those things afterward u have nothing to show for your money its a waste - a good waste but still makes me cry everytime i have to fork out heaps for a drink :D
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nahh i cant really get out there, for some reason im the only person in a rather large group that can count. Ok i had 1 beer that means 1 hour, its not that hard.
So im drving the platoon to mt lawley to see big dave miller play at the velvet lounge
Clients are good to deal with none of em give me hassle cause i just dont take it off em. the only problem is ppl who are just morons now that can get annoying. Oh and companies that are moronic by design, thats even worse
heheh they wernt that bad i have seen worse. i always drink and drive ive been plulled over heaps of times too.
Go out and drink to ure hearts content. Go back to where u parked and count how many drink uve had wait the designated amount of time then drive home. If u cant count ure beers, dont bother, leave the car there. its a good technique
haha 7:20 thats very precise paul!! ok no probs i'll have the gates oh hell opened for u :D
One day i will skipper u pauly although if your saw my designater driver act last weekend u are probably not to eager for that day haha
shaun so many companies are badly managed and really it means the difference between life in death of the company. Its sad cos it ruins the employees morale which then in turn ruins sales etc
my take on things anyway
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
