  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
cool thanks but  I was thinking you can better thant that with that picture... with my car...
make it negative and add few letters rather than blur... I cant make out the car :D
ok.. i'll see what i can do..
coz after all.. i only did those in like 5 mins..
Originally posted by Nizmo
buh bye - i dont know - shee can figure out - dont mean to be mean but what are we suppose to do - aint got no magic wand to turn a pumpkin into a coach
anyway see ya tonight.
I didn't mean to inconvience anyone - I asked Paul to find out for me cause I can't just go on the internet at work as my boss sits next to me.
Sorry to pi*ss people off
i didn't mean to be a pain - its just that I can't go on the net heaps at work cause my boss sits next to me and it all gets logged. I apologised to Paul for being a pain. Its just that i really wanted to go.
Andrew is going to work on the speedcar tonight so he needs his car... otherwise I would drive the falcoooon
Originally posted by skyzerr33
hmm u near the train? Liz
catch it up to currumbine station then they can get u from there only a 5min round trip to mickos
Yeah I am - but they said in earlier posts that there was no one to pick me up. Its cool.... I will watch dvd's I got from thailand and drink my bottle of wine!!!
Liz , get your ass to Currambine.
I will pick you up if you ring me .
Will be at Mickos or on the way there.
we would all love to see you.
I would get you from home but I live NOR .
Cheers
Ken
ps my number is 0418 927 415 cos no ones gonna stalk me so I don't mind posting it . hehehe
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
