  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
cool thanks but  I was thinking you can better thant that with that picture... with my car...
make it negative and add few letters rather than blur... I cant make out the car :D
ok.. i'll see what i can do..
coz after all.. i only did those in like 5 mins..
Originally posted by Nizmo
buh bye - i dont know - shee can figure out - dont mean to be mean but what are we suppose to do - aint got no magic wand to turn a pumpkin into a coach
anyway see ya tonight.
I didn't mean to inconvience anyone - I asked Paul to find out for me cause I can't just go on the internet at work as my boss sits next to me.
Sorry to pi*ss people off
i didn't mean to be a pain - its just that I can't go on the net heaps at work cause my boss sits next to me and it all gets logged. I apologised to Paul for being a pain. Its just that i really wanted to go.
Andrew is going to work on the speedcar tonight so he needs his car... otherwise I would drive the falcoooon
Originally posted by skyzerr33
hmm u near the train? Liz
catch it up to currumbine station then they can get u from there only a 5min round trip to mickos
Yeah I am - but they said in earlier posts that there was no one to pick me up. Its cool.... I will watch dvd's I got from thailand and drink my bottle of wine!!!
Liz , get your ass to Currambine.
I will pick you up if you ring me .
Will be at Mickos or on the way there.
we would all love to see you.
I would get you from home but I live NOR .
Cheers
Ken
ps my number is 0418 927 415 cos no ones gonna stalk me so I don't mind posting it . hehehe
