and today she will tell us how she has been in hospital three times and she is having her 10th hysterectomy hahahah Drew is cool though he always says "shut the f*uck brooke no one cares" hahaha he has had to deal with it all his life so I think he is like 10000 times more sick of it than me hahah
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha BROOKE anyone by that name i know is a god damn bitch so it figures!
Rice is crap, im not an egg person, but i'll have bacon, toast and mushrooms pleease mmmmmm mushrooms - wonder if the markets are open today all these food things that i now think i need
Originally posted by Nizmo
lol @ ken for carrying on da tanya joke
Joe the crew is welcome anytime - kens always outside the window anyway :)
Liz haha glad to see u are keeping up the tradition of disliking the in-laws, always drink lots so your happy but not drunk at those gatherings and you'll get thru it fine.
Nope , not any more, have found a new window to lurk outside.
Shame it's on the 1st floor. Hanging on to the window sill hurts my fingers.:)
Liz , get pissed , make an animal of your self and they won't invite you back. Drew will get over it eventually.:O
Cheers
Ken
ohhh and btw , thanks Micko for being a good host .
Now you know not to leave a bowl of chips anywhere near Kyles.
Did you get the turbo boost dustbuster cranked up nice and early ?
Bet that Naomis wishing the room would stop spinning.:)
Chgeers
Ken
haha yeah liz that movies is one of my all time favs :)
haha its so you can be more like christ - but hey why try and follow in the footsteps of someone perfect? Life with sin is sooo much more fun :O
Ken I have tried being a bitch... I kicked his sister out of our house, I told his mum that I didn't care she was divorcing andrews dad and to stop telling me about it.... but then andrew gets all shitty at me hahahaha So now I just act like I'm deaf and I don't know how to talk
who lives on the first floor ken?
*niz pretend to be hurt* is she better looking than me? i dont do it for you anymore? hahaha *j/k* :)
Niz , you ALWAYS do it for me . Please don't get hair extensions , I haven't got enough tissues.
All women are beautiful , especially ones that actually talk to me. hehehe
cheers
Ken
haha yeah i cant believe how many times kyles knocked things over - she was a human bowling ball haha bet troy was probably sulking more when he finds out what a good time she had without him :)
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
