haha ken below the belts right :) Paul brought marshmellows - i was what tha? we going to play fluffy bunny or something (put amarshmello in your mouth say fluffy bunny and keep repeating til theres no room left in ya mouth
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Just remember peeps , this is whoretown and everything ( almost everything ) I say is in good humour and I cannot be held responsible for.
If you don't like any comments I make then
Too bad . hehehe
Cheers
Ken
Originally posted by Nizmo
haha yeah i cant believe how many times kyles knocked things over - she was a human bowling ball haha bet troy was probably sulking more when he finds out what a good time she had without him :)
nah i'm use to that she always has a good time without me
And niz check your PM and give us an answer.
I am off to pull a manifold ( the cars , not mine you dirty people ) and will catch you in about , ohhh... 8 friggin hours.
Cheers
Ken
ps bye Liz , remember , the worst they can do is dis own you and is that all that bad ??
we've seen paul drunk - he sleeps haha :) the whole forum has seen that picture!!
Ken u dont offend me haha i would be disappointed if ya didnt have a good sense of humour - people that take themselves too seriously are no fun!!
Buh-bye Liz - sorry once again matey!
Don't worry Troy , it wasn't like we were playing spin the bottle.
* sshhh you lot , don't tell him *
Cheers
Ken
Originally posted by gtrken
No pics , WAAAAAY to incriminating.
Have you rung Kyles to see if she's surfaced ?
I don't want to cos she might think I'm stalking her. * insert evil laugh *
Cheers
Ken
if she had afew and got home at 2ish she want be up till about 3pm
we've seen paul drunk - he sleeps haha :O the whole forum has seen that picture!!
Alas Niz , at my age , a sense of humour is ALL you have.:)
Cheers
Ken
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
