haha ken below the belts right :) Paul brought marshmellows - i was what tha? we going to play fluffy bunny or something (put amarshmello in your mouth say fluffy bunny and keep repeating til theres no room left in ya mouth
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Just remember peeps , this is whoretown and everything ( almost everything ) I say is in good humour and I cannot be held responsible for.
If you don't like any comments I make then
Too bad . hehehe
Cheers
Ken
Originally posted by Nizmo
haha yeah i cant believe how many times kyles knocked things over - she was a human bowling ball haha bet troy was probably sulking more when he finds out what a good time she had without him :)
nah i'm use to that she always has a good time without me
And niz check your PM and give us an answer.
I am off to pull a manifold ( the cars , not mine you dirty people ) and will catch you in about , ohhh... 8 friggin hours.
Cheers
Ken
ps bye Liz , remember , the worst they can do is dis own you and is that all that bad ??
we've seen paul drunk - he sleeps haha :) the whole forum has seen that picture!!
Ken u dont offend me haha i would be disappointed if ya didnt have a good sense of humour - people that take themselves too seriously are no fun!!
Buh-bye Liz - sorry once again matey!
Don't worry Troy , it wasn't like we were playing spin the bottle.
* sshhh you lot , don't tell him *
Cheers
Ken
Originally posted by gtrken
No pics , WAAAAAY to incriminating.
Have you rung Kyles to see if she's surfaced ?
I don't want to cos she might think I'm stalking her. * insert evil laugh *
Cheers
Ken
if she had afew and got home at 2ish she want be up till about 3pm
we've seen paul drunk - he sleeps haha :O the whole forum has seen that picture!!
Alas Niz , at my age , a sense of humour is ALL you have.:)
Cheers
Ken
