haha ken below the belts right :) Paul brought marshmellows - i was what tha? we going to play fluffy bunny or something (put amarshmello in your mouth say fluffy bunny and keep repeating til theres no room left in ya mouth
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Just remember peeps , this is whoretown and everything ( almost everything ) I say is in good humour and I cannot be held responsible for.
If you don't like any comments I make then
Too bad . hehehe
Cheers
Ken
Originally posted by Nizmo
haha yeah i cant believe how many times kyles knocked things over - she was a human bowling ball haha bet troy was probably sulking more when he finds out what a good time she had without him :)
nah i'm use to that she always has a good time without me
And niz check your PM and give us an answer.
I am off to pull a manifold ( the cars , not mine you dirty people ) and will catch you in about , ohhh... 8 friggin hours.
Cheers
Ken
ps bye Liz , remember , the worst they can do is dis own you and is that all that bad ??
we've seen paul drunk - he sleeps haha :) the whole forum has seen that picture!!
Ken u dont offend me haha i would be disappointed if ya didnt have a good sense of humour - people that take themselves too seriously are no fun!!
Buh-bye Liz - sorry once again matey!
Don't worry Troy , it wasn't like we were playing spin the bottle.
* sshhh you lot , don't tell him *
Cheers
Ken
Originally posted by gtrken
No pics , WAAAAAY to incriminating.
Have you rung Kyles to see if she's surfaced ?
I don't want to cos she might think I'm stalking her. * insert evil laugh *
Cheers
Ken
if she had afew and got home at 2ish she want be up till about 3pm
we've seen paul drunk - he sleeps haha :O the whole forum has seen that picture!!
Alas Niz , at my age , a sense of humour is ALL you have.:)
Cheers
Ken
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
