  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
sounds like kyles is giving niz a lap dance
huh? Troy if you just crossed that off ya fantasies list you may want to put that one back of cos kyles didnt give me a lap dance haha *get those dirrrty visions out of your head boys* :P
hahahah speaking of lap dance...
Well its my mate Jame's 23ed birthday and guess where we are going tonight :P:)
hahahhaahhahahah if anyone there I'll meet you all there... oohhh yeah its at near north bridge I think :D (can you confirm this Paul?)
ps. why O why Australia do not have $1 bill eh? :D
cheers
Joe
ahhh going to see skanks get their gear off n pay for the privledge haha men = stoopid. Mel and I are going to Rise tonight for public domain.
Hey dark :P
I feel like maccas breaky but its too late. mmmm greasy hash browns
buy at the door Joe - but Rise send me discounts.
A skyline just went up the main road near my house - couldnt see it but i could hear it :P
mmmm bacon is cooking. So where were u last night joey?
Originally posted by darK
cant u just use coins?
Young darky you have much more things to learn boi!
Coins are hard to stick on G's I would if I can...
but Coins are need for peep shows... :D
Niz- its all good fun, I bet ya you would love to go and see chippendales (spell). ohhh come on like you never seen naked human being b4! :P
but Coins are need for peep shows... :P
oh ok.. i thought you WERE going to a peep show..
yea.. it would be kinda hard to stick a coin into a G..
*thinks
haha.. lol
A skyline just went up the main road near my house - couldnt see it but i could hear it :)
I was having early night... borded too... then got a call from Tanya.. spoke to her for while about exam next week etc..etc. and other which I am not liberity say. :P
she is good friend :D damm I dont need another Friend that is female...:D! I got too many already.
anyway I was saving my liver for tonight :)
so what about you NIZ so Kyles gave you lap dance? who was on top? heheh :) boyz behaved?
see ya joe :D
mmmm bacon toast n mustard yummo - putting my greasy paws all over ther keyboard tho
Joe - friends out last lovers :P so dont complain - some of the best relationships come out fo friendships too.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
