  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hi all. First post whoretown, so be gentle please.
Quick intro i guess. Names Mat and i within next month or so i will have a r33 in the garage!! yay. So yeh, g'day i guess!
Kyles, Rather than hire the equipment have you thought about doing a SCUBA course through PDA or something. It works out really well and they provide gear and you get a couple of pool dives and some dives over at rotto if your lucky!
mat
