  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Troy I can see what your doing but its not going to work :D
Why did u no come out on Thurs? u had night off!
Joe - i wasnt getting blind and it wasnt all the time - i got thru school fine and got into all the smart classes so no it didnt affect anything but probably my liver :)
Originally posted by caminperth
joe - which building? i'm in the one on mill st.. he'd be based at the central park office right?
uumm.... ok his name is Frank Matera... (football palyer link maybe :D). I think he is at main
but my other mate applied Help desk job from the paper, waiting for reply... I dont know that's how you got the job but maybe you took the same position... not sure :confused: heheh
Originally posted by skyzerr33
doh
why cause i had to go home and provide the $$$ for the grocery shopping and then clean the house friday morning.
well I was listening to convos between Niz & Kyles... (its really hard not to hear.. cuz they were sooo loud!) she was up set that you wasnt there :D....
Troy boy how could you let her down like that eh? heheh :)
bad boy bad!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
