  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ken is going to get a pic tomorrow if he has time and send it to me. He is SO helpful! I am test driving the one at c-red tomorrow and looking at this other one saturday or next week. Ken said he's put it on the hoist for me, and give it a good looking at.
Neo - revs car is silver?
I have put in all the time around making the car better to drive.
It is my work vehicle and as such I wanted to improve fuel ecconomy,power and smoothness.
All my mods are based on making the stock components work more efficiently. I think several people would be suprised at how easy good times can be extracted from my car.
Looks stock and drives better/faster (even better fuel ecconomy).
