1. Intelligence.
2. Sense of humor.
3. Passion
4. Consideration
5. Honesty
6. Flexibility
7. Serenity
8. Balance
9. Ambition
10. Attentiveness
^ obviously not written by me cos all that = a gay guy!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
1. Intelligence.
2. Sense of humor.
3. Passion
4. Consideration
5. Honesty
6. Flexibility
7. Serenity
8. Balance
9. Ambition
10. Attentiveness
where is looks..???
yeah i was thinking wheres the butt and eyes and smile - maybe im just shallow!! but serenity? sounds boring - geez i dont want to go out with a monk!! I think they just took out basically everything that makes a guy interesting!! sure they should have some of those qualities but i think a guy with all of them would bore me absolutely!!
Aidwin - *sigh* it has a badge and an extra turbo and an extra $10,000 to pay for one to me - thats the only thing that sets them apart - nice car, wish i had one but its like a Holden Clubsport and a Holden GTS - look the same - different badges, different power ratios, different price tags thats it!
All that dancing must keep you fit Liz!
Niz - yeah I am fit... but I don't look it unfortunatly. irish dancing makes my legs thick... it sucks hhahaha
Drifta - the other one I have not seen.... I will see it next week. He wants about 24K for it I think... 96 series II - no mods... sounds pretty good. But I love that one at c-red...
ralph mag website probably has some - hehe utter crap but funny.
Going down is:
Just the tip of the iceberg when it comes to things you can do in bed.
A phrase heard in lifts. :P
Best when reciprocated
Hope i didnt make anyone blush - just thought it was funny.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
