  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i dont mind drunk ppl at my birthday - but if u need to puke please do not miss the bowl!! nothing worse than cleaning up other ppls vomit - specially if your hungover yaself!
Anyways night!!
haha....
well. the blue tail light has become a comedy of errors frankly.
Im awaiting a part from Jaycar, on thursday, at which time blue light will be go.
as for hearing me from your house, the answer is : not yet, but its not far away.
transfered "the array"from the front of my old car onto the back shelf, and have the 15 in a temporary install using tie down straps. got splits to go in the doors today. once that happens, i will fiddle the gains as best as possible and from then on its alll goood baybbeee!!
nah. not yet. I figure theyre probably pretty well deadened to begin with, and are not likely to be the weak link in the system. will install tha splits in the doors and se how they sound. If I get horriffic secondary resonance I will bitumen them (more).
skylines in stock trim are pretty chock full of sound deadener though. cant see it being an issue..
