  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hi Troy!
Well Paul, I don't want you to leave us with Kym trying to take your spot ever again. I have not forgot what it was like yet. That is all. Remember I was even crying!
I am not hungry, just had a chocolate.
Originally posted by SHUTO-BOY
jason: meet cam at the moon first i think
just to clear up the confusion, IF this is caminperth, it will be the moon cafe, near corner of Newcastle (and William ?? St ) in Northbridge. Monday/Tuesday are cheap pasta rituals.
btw,
I dont know how you lot manage to hold down jobs. your productivity must be next to zero!!
Yes, that bad, it took me 3 hours to get the fire story. Did you read that? He put flammable stuff on the desk and lit it up, accidently of coarse, like cops might fly! I knew 3 people who went to school with him and I know tonnes of stories!
I love giving him a hard time so you are no longer the target of my meaness. I have lots on him, he has nothing on me!!!
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
