  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Bayley,
Of course I take it back, your a realy hottie, I was just upset cause you have a bf:D
See'ya:burnout:
Oh, well thats ok then, I am happier now. Still, you have to earn my trust back now. I will keep being nice though.
Niz, I tell ya, Irenen done it!
tried to order in an adapter for a jap to aussy aerial thing.
would not beleive the bullshit I went through to get some knumbscull to place the order.
"eeeer you'll have to call back later"
"why dont you just write him a ****ing note!?"
" eeeer, ok, but you'll need to come in and make a deposit"
"What? Why? Cause Ive phoned you ten times cause I dont want it? WTF?"
"Im sorry, but you'll have to make a deposit and come into the store before you order it"
"****. I'll just pay for it now with a credit card"
"eeeeer, I'll take the credit card number as a deposit."
"no, I'll just pay for it now. here's the number"
"eeeeer, no. I cant take a credit card payment."
"why not?"
"I'll take it as a deposit"
"why cant i pay for it on the phone?"
"eeeeer, I cant do that"
"sure you can. what happens when you take a mail order?!?"
"eeeer, that's different"
"FOR ****S SAKES YOU LITTLE SHIT!!! YOUR PISSING ME OFF"
"eeeeer...."
...so now some pimply **** has got a card lying around the desk at a busy store with my cc details on it, but only as a deposit. he cant pay for it......
Like ****ing Rainman!!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
