The patient has been transferred to National Taiwan University Hospital. Lee said the patient's long-term drug addiction had led to the weakening of his immune system. < there u go drug abuse could lead to SARS
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Sounds pretty typical zanda.
Oh, that is so sweet, Troy and Kyles, don't worry, me and my b/f are like that too. I get lots of calls from him from his work too.
I can't ring from here though, all calls are monitered.
Originally posted by zanda
tried to order in an adapter for a jap to aussy aerial thing.
would not beleive the bullshit I went through to get some knumbscull to place the order.
"eeeer you'll have to call back later"
"why dont you just write him a ****ing note!?"
" eeeer, ok, but you'll need to come in and make a deposit"
"What? Why? Cause Ive phoned you ten times cause I dont want it? WTF?"
"Im sorry, but you'll have to make a deposit and come into the store before you order it"
"****. I'll just pay for it now with a credit card"
"eeeeer, I'll take the credit card number as a deposit."
"no, I'll just pay for it now. here's the number"
"eeeeer, no. I cant take a credit card payment."
"why not?"
"I'll take it as a deposit"
"why cant i pay for it on the phone?"
"eeeeer, I cant do that"
"sure you can. what happens when you take a mail order?!?"
"eeeer, that's different"
"FOR ****S SAKES YOU LITTLE SHIT!!! YOUR PISSING ME OFF"
"eeeeer...."
...so now some pimply **** has got a card lying around the desk at a busy store with my cc details on it, but only as a deposit. he cant pay for it......
Like ****ing Rainman!!
guess which pimply little toad is going on a porn site membership shopping spree in your name :elaugh:
Originally posted by skyzerr33
check the tshirt orders thread he offered to pay for yours
Well, thats good, saves me $30.
Play nice Paul, I am not nice, not playing nice!:bahaha:
Drugs lead to SARS hay, mmmm, I know a few dead chickens.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
