Originally posted by Sneeza
Ken - what?? I was serious :D hahahaha If you could check it out that would be GREAT!!!! i will email jeff and let him know... but don't make a special trip down there for me..... only if your there anyway!
Wait till after you check out the series 2. Will give you something to compare.
btw , you should see the red series one he got off the wharf this arvo.
Cool stuff like a HKS digital display in the middle of the cluster , remote start, adjustable in cabin drift control , Jun stickers on it , bride seat and harness....
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
Great way to go to sleep.
Ahhh , volk te37's , advan rg's , HKS 2530's , Apexi power FC.
Bah , who needs counting sheep.
Cheers
Ken
Find what you want there then go give brent a call from nengun.
Ken
When are you racin? Sat Sun Both? Is there an elimination?
Cheers
Ken
sounds hardcore must go hav a look one day
Ken - yeah I plan on seeing the series II early in the week. So I will give you a call and have a chat to you about it.
i have seen the red on on the website I think... is that one that looks like a drifta with the different back wheels?
Nope , he only got it off the truck about 5 hrs ago.
Cheers
Ken
yea , call me when you are going to look at the series2
Ken
Saturday , Collie circuit for Sprint laps against the clock
Sunday , Wellington dam hillclimb .
Cheers
Ken
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
