  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
I think my spurt of cleanings ended damn! I woke up.. felt like cleaning my waldrobe, pulled everything out and its spread over the bed and floor.. and now the drive to clean has stoped.. what to do? Wait till troy gets home hehehehehehe
ok ok troy boy calm down.. im going im going.. doing it now... hehehe
ken, Troys not coming over untill after work at 7
Ahhhh , so thats why the tail party tonight was cancelled ( didn't write c o c k cos it would only be deleted ).
No Troy for a week and then tonight.
Hmmm , two bangs , one as the door closes and one as Kyles hits the bed.
* did I just think that ?? *
Cheers
Ken
Originally posted by skyzerr33
lol she felt like cleaning till she found an old pair of shoes growing in the closet.
but ken do have rims to go with the tyres :)
Don't want much do you ?
If I had the rims , I wouldn't have to waste money on 17's would I.
Cheers
Ken:D
And if you don't Troy will give you a good spanking.
Ohh that's right , you LIKE good spankings...
Cheers
Ken
na it was canned because my best friend forgot and decided to go down south.. cant have a party with out dom. So troy boys bdays coming up its going to be then ..
GO AND CLEAN YOUR ROOM !!
you naughty girl , look at the mess you've made.
Hehehe , do I sound like your parent(s).
Cheers
Ken
If you knew the stuff I used to get up to when I was younger than you lot ( so before you were all born , yea shaddup ! ), you would look at me a whole lot different.
Lets just say I was in a car club full of older ( ie licensed and alcohol legal ) when I was 14yrs old.
Cheers
Ken
see its all coming out
kens an old skool bogan alchol hoon hehe
nah kylie will get more than two bangs
and kyles micko sent out a pm with details
*SOB *
yep , I miss the corduroy flares , purple cravat and paisley shirt.
Also miss by Falcon 351 panel van with the mirrors on the roof and the very shagged pile carpet.
Ahhh , those were the days:D
Cheers
Ken
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
