Guest 87vlt
Originally posted by Boostzor
Yep sounds like u need to get a girl there Vspec. I met this great girl called Marie Jane she keeps you calm when your in the car and stops you from speeding too. Even  makes big brother watchable :bwhaha:
stops you from speeding or just causes you to drive at like 15kmh even though you think your doing like 110kmh .....
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeh i was saying that prescriptions arent much better then illicit. They still work on the same principal and just casue u got them off a guy in white coat dont make them any better. Behaviour modifing drugs are more often then not used as a quick fix when really the solution is with the individual.
Sorry i like this subject alot:D
i know a few ppl on all sorts of prescription stuff and in most cases they take a turn for the worse.
Well i wont deny my driving needs improvement - mainly cos i live in la-la land but thats only because im going so slow i put myself to sleep. Once the foots down i reckon my drivings fine :D
Yeh big brother definately requires at least 4 pints before it get interesting. What was wrong with seinfeld? they could repeat the same ep over and over and id still watch it.
Just goes to show how many morons there are in the world huh
Yes i can also say that i think a lot of prescription is on the same level if not worse. Some people don thave a choice in their lifestyle - they just kind of get dragged into it - good on the ones that drag themselves out again :D
Oh yeah i run people off the road alright haha mmmmmm bullbar = instant power trip! But these were vehicles that were going to be sent up to the mines - i dont think they should be used for taking bob & jane to school every morning!!
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
