  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
c) speak for your self mr! LOL
D) Females excepted ( mind you , doing it on the couch , rug , floor , shower , bed , table , verandah , car ... ) I suppose constitutes a limited life.:(
Cheers
jealous
Ken
Neo - we found one & I left the gate open for the other one as I spent around an hour walking the streets looking for the little bugger...he was waiting at the door when Paul got up at 5am.
btw - I saw you this arvo going up to PSI as you crossed over Wanneroo Road. I had already been there & as you would have found out they did not dyno cam's car today.
how do brownies work if you sit and watch telly??
Wouldnt work for troy.. he would loose em.. because it would be all geeky sifi crap
Means I'm in the same room. She is easily amused the One Who Must Be Obeyed
Cheers
brownie collecter
Ken
hey guess what? mums coming down in convoy with us in the lazer hehe.. she will probly beat us down there the hoon. Shes going to try and borrow a porche of a good friend of ours and borrow that.. pitty our friend with the lamb isnt in perth.. shes in albany.. damn. They used to have a helicopter too
gez it would be nice to be loaded
Make sure she doesn't pass Willy.
Hmm , it's hard NOT to pass Willy when he drives at 5 under the limit. Hehehehe
Cheers
Ken
    • Photo quality is terrible, but there's a few things on that board that give me suspicions it has some issues. Add to that, I'm hoping the cut and exposed wires under the dash were not exposed or touching each other before you pulled that all apart.
    • Stories like this are why the immobilizer installs I've done are 100% reversible. No harness cuts.
    • update; Replaced oem starter motor with a Jaylec 70-61111 car still didn't start, moved over to the alarm system unraveled the spaghetti checked the solder end points, PCB board burn smell, wiring ends, capacitors, water damage everything looked fine restarted car vroom. restarted 5 to 6 time over an hour started put every thing back together only to not have it start any more. looks like i will be removing the alarm system next weekend.
    • Lots of people. Could be a lot of things like people have said. Either the heater hose/pipe, the turbo coolant return that wraps around the back of the engine, or a core plug. I have seen all three. If you want me to guess wildly though I would bet it's one of those hoses for the turbo coolant return. Or the brazing/welding for the Y- section has failed. Get a borescope down there to be 100% sure.
    • FWIW, I've aerated oil, and cams snapped. You can figure out the rest 🥲
