  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Kyles
spike just got his head cought in one of his toys.
Oh guess what the little bugger did today. He was sitting just below my neck next second his heads in my cleavage and hes chewing on my bra.. i lost it laughing.. I dont think troy was impressed.. he grunted when i told him.
Ohh lucky , lucky bird.
* now wheres that weiro gone *
Spike replies
* Help , help , i'm going under *
Cheers
Ken
Originally posted by Neo
Ken
Can you recommend anyone for a front/dump fabrication. Would like to keep it tidy??
paul would be the one to ask.
I use Butler exhaust or Exhaust dynamics but the are NOT cheap.
Cheers
Ken
JOE what are you still doing here.. gez this girl will dry up and go home before you get to her.. or she will do the job herself.. get in there boy!!
or was that puncture and blow out the window ??
Cheers
Ken
Originally posted by caminperth
hey guys.. hows things.. me just had some fun at kwinana.. unfortunately it's going to cost me a new clutch.. doh!!
And another ones gone , another ones gone , another one bites the dust...
Cheers
Ken
neo - 1st run me driving car did it's best.. 13.63 @ 163km/hr
2nd run my dad had a go - got excited and cooked the clutch..
I did two more runs - both 13.7.. way home clutch was slipping badly.. 1/4 throttle in 5th gear = lotsa revs - no go... :(
looks like my new clutch is going to happen way quicker than I thought...
or did you have the same problem that guy off america pie had with the exchange student in his room had??
was that the one where he gave her a lovebite , she farted in his face and blew out the window ?
or maybe not:D
Cheers
Ken
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
