  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
neo - not on the first run.. things got a bit hot by the last one so it was pinging a little.. but to it's credit i was running 0.9bar!
as for the blame it on dad - the clutch was pretty hammered by me beforehand over the last year.. he just cooked it for the final time...
Originally posted by Kyles
what american pie did you watch??
The scene where hes on the bed sitting next to the girl and goes to touch her and blows himself.. a few times..
Watch ... ?
I was talking from experience.j/k
Cheers
Ken
Originally posted by caminperth
ken - drag racing is good - u just have to not get excited at the launch.. :(
hmmm , the more money you spend the quicker you are and the less time on the track.
Yep , that sounds like fun...
Cheers
Ken
Originally posted by Micko
Where are you boing for a new crutch cam?
Ross @ Autoclutch seems to be the go:thumbsup:
not sure.. am going to check it out tomorrow if work allows it.. ie - me not too busy... good thing is i don't have to drive to work so it can rest for a while...
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
