lol @ paul... the 2nd run did it the damage - there was no problems after the 1st run.. it was fine.. probably would've made a month or more....
at least the old man offered to pay half.. :D looks like that flywheel will HAVE to go with the clutch hey?!? hehehe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah I thought so.... yours had the "wing" license plate or something similar from memory.... It was very nice from what I saw of it... I hope it goes well when you get it back then... I was on that cruise but busted my clutch on the way there so had to go home early ..... If you could smell a car with a burnt clutch that day... that was me :D
Cam... that included all the labour as well.... it was the total price to pay.... I had the option for the heavier pressure plate but I opted for the slightly lighter option as I wanted my car to still drive like a stocker .... i.e no real heavy clutch work....
Yeah I was lucky..... I did search for a little over a month to find my line but this one had everything I was looking for in the one package.... and it was in great condition..... I have had absolutely no regrets buying this one!!!! Well apart for the fact its not an "R" but hey we cant have everything :D
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
