lol @ paul... the 2nd run did it the damage - there was no problems after the 1st run.. it was fine.. probably would've made a month or more....
at least the old man offered to pay half.. :D looks like that flywheel will HAVE to go with the clutch hey?!? hehehe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeah I thought so.... yours had the "wing" license plate or something similar from memory.... It was very nice from what I saw of it... I hope it goes well when you get it back then... I was on that cruise but busted my clutch on the way there so had to go home early ..... If you could smell a car with a burnt clutch that day... that was me :D
Cam... that included all the labour as well.... it was the total price to pay.... I had the option for the heavier pressure plate but I opted for the slightly lighter option as I wanted my car to still drive like a stocker .... i.e no real heavy clutch work....
Yeah I was lucky..... I did search for a little over a month to find my line but this one had everything I was looking for in the one package.... and it was in great condition..... I have had absolutely no regrets buying this one!!!! Well apart for the fact its not an "R" but hey we cant have everything :D
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
