  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh nothing like the old $500 to buy $500 to install feeling. Its generally a 1/1 ratio. Thats y u should try to do most of the work yourself like services and all that small stuff. Plus if u want something done its good to rip the part off and take it in for them to work on as opposed to making them pull it out.
i think the work wouldve been alright if i owned a little hyundai but because i worked for the general car industry not the import a lot of them didnt realise what kind of work was involved or wha thtey were looking at in regards to the ZX.
I would like to be able to do stuff like that but as my car came with a warranty I need to get authorised mechanics to carry out 6 monthly services... the next one will be the big 100,000k's service to.... not looking forward to that one ....
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
