  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
thanks man.. i'm ok.. just sick, tired and sad... shit happens i guess...
as for compromise - tried everything i could think of bud.. some things just won't work... guess fear plays a big part sometimes..
should be bedtime round now i think.. need to try to get to work tomorrow for extra $$ for the new clutch!! doh..
sneeza - thanks... did make me smile after thinking of the torries down at kwinana last night.. hehehe...
yea - that mostly.. nothing else really.. makes it kinda hard..
anyways - me need to sleep now i think... nite guys.. thanks for the kind words...
Originally posted by SHUTO-BOY
heheh ken,what u up to this weekend? any racing?
Not for me , am team managing 4 cars in conjunction with Dean Herridge for Maximum Motorsport at Lewana ( State Rally championship round )
Cheers
Ken
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
