  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
You want to be a navigator? Do they get paid or do it just for fun?
See'ya:burnout:
Paid ??? hahahaa
No , just for fun , glory and Trophies.
btw , the trophy for 2nd o/r at Wellington was a big GT3 porsche. Bugger !! no F1 car.
Cheers
Ken
Would appear that Steve ( SST ) and Mr winfield look alike Gray in the GTST had a bit of falling out.
Was speaking to Steve and he said that a smaller turbo was fitted cos Gray was blaming that.
Cheers
Ken
ps Wholagan is still waiting for steel forks for the ppg box.
Did you see AJ drive today? He didn't get to do many laps.
Who's second in 4WD? Seymour?
See'ya:burnout:
Supposedly has 450hp atw but doesn't seem like it. Is the JUN engine but with a supercharger.
Engine was getting hot so AJ parked it. I would too knowing the cost of that motor.
Cheers
Ken
Yeah, I spoke to Steve a fair bit, won't go into details on what he thinks of Gray:D His little Datto was doing alright for it's first run.
Steve Maitland was going well until he went in too deep on the last lap.
Spoke the Graham Stones, his car was flying, but has got gearbox problems.
See'ya:burnout:
See'ya:burnout:
Caratti made a few enemies when he had a coming together with Anderson ( Racetune prepped Escort ) and Matt Cherry in the red RX7 that hit the wall.
Cheers
Ken
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
