  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
You want to be a navigator? Do they get paid or do it just for fun?
See'ya:burnout:
Paid ??? hahahaa
No , just for fun , glory and Trophies.
btw , the trophy for 2nd o/r at Wellington was a big GT3 porsche. Bugger !! no F1 car.
Cheers
Ken
Would appear that Steve ( SST ) and Mr winfield look alike Gray in the GTST had a bit of falling out.
Was speaking to Steve and he said that a smaller turbo was fitted cos Gray was blaming that.
Cheers
Ken
ps Wholagan is still waiting for steel forks for the ppg box.
Did you see AJ drive today? He didn't get to do many laps.
Who's second in 4WD? Seymour?
See'ya:burnout:
Supposedly has 450hp atw but doesn't seem like it. Is the JUN engine but with a supercharger.
Engine was getting hot so AJ parked it. I would too knowing the cost of that motor.
Cheers
Ken
Yeah, I spoke to Steve a fair bit, won't go into details on what he thinks of Gray:D His little Datto was doing alright for it's first run.
Steve Maitland was going well until he went in too deep on the last lap.
Spoke the Graham Stones, his car was flying, but has got gearbox problems.
See'ya:burnout:
See'ya:burnout:
Caratti made a few enemies when he had a coming together with Anderson ( Racetune prepped Escort ) and Matt Cherry in the red RX7 that hit the wall.
Cheers
Ken
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
