  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
You want to be a navigator? Do they get paid or do it just for fun?
See'ya:burnout:
Paid ??? hahahaa
No , just for fun , glory and Trophies.
btw , the trophy for 2nd o/r at Wellington was a big GT3 porsche. Bugger !! no F1 car.
Cheers
Ken
Would appear that Steve ( SST ) and Mr winfield look alike Gray in the GTST had a bit of falling out.
Was speaking to Steve and he said that a smaller turbo was fitted cos Gray was blaming that.
Cheers
Ken
ps Wholagan is still waiting for steel forks for the ppg box.
Did you see AJ drive today? He didn't get to do many laps.
Who's second in 4WD? Seymour?
See'ya:burnout:
Supposedly has 450hp atw but doesn't seem like it. Is the JUN engine but with a supercharger.
Engine was getting hot so AJ parked it. I would too knowing the cost of that motor.
Cheers
Ken
Yeah, I spoke to Steve a fair bit, won't go into details on what he thinks of Gray:D His little Datto was doing alright for it's first run.
Steve Maitland was going well until he went in too deep on the last lap.
Spoke the Graham Stones, his car was flying, but has got gearbox problems.
See'ya:burnout:
See'ya:burnout:
Caratti made a few enemies when he had a coming together with Anderson ( Racetune prepped Escort ) and Matt Cherry in the red RX7 that hit the wall.
Cheers
Ken
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
    • The pinchweld is fine, even with a trolley jack, so long as you're not actually pushing on the pinchweld itself. More to the point, we shouldn't talk about lifting or supporting on the pinchweld, we should talk about using the sill "jacking points", which just happen to be adjacent to the pinchweld. I just have dense rubber blocks with grooves in them for each of the chassis stands and the trolley jack, that I use at the sill jacking points if/when I have to lift/support there. They put all the load onto the steel pad of the jacking point and not the pinchweld. As intended.
    • Makes sense.  I would do something different if I felt like there was a better option. Generally the only other area I'm happy to jack on is where I want to put the stand. The pinch weld is not an option for me for either the jack or stands, so very limited options overall.  Plus never having had an issue with doing this, has kinda reinforced in my mind that it's fine. I'd do it on any car without a second thought these days lol.
    • I know on some cars it's explicitly endorsed in the service manual but a lot of them it isn't which is what gives me pause. I know a lot of cars also have you jack up the car by the radiator core support which is a lot easier to get to than some crazy deep section of the front subframe. I'm just reluctant to find out if any of that is really safe to do if not listed in the service manual. The FK8 has even the R-chassis beat in this regard, the front subframe jack point is almost fully behind the front tires and is surprisingly recessed into the car.
