  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Yes, Aaron was a little OTT with his driving at times. Anderson is a good driver and didn't need that. I'm not sure if the RX7 was also to blame, hard to tell from my angle.
Seems that Kerry Wade is still holding on though.
See'ya:burnout:
Matt was on the line but a little behind.
Aaron should have given him some room , hit so hard that the RX7 bounced over the inside kerb and broke the LH lower balljoint which is what put him in the wall.They aren't playing for sheep stations and he will get a reputation like Mitchell where everyone will suddenly gang up on him.
Cheers
Ken
Cheers
Ken
Will the Lola be able to make up enough points to win the championship?
See'ya:burnout:
Don't know but I will have to come 2nd or 3rd to keep my chances alive.
Cheers
Ken
Hehe, you dirty man Ken:p Don't worry Kyles:D
See'ya:burnout:
Dirty , why so.
You guys discuss the female form and it's banter and flirting.
I discuss it and it's dirty:D .
Cheers
Ken
Ken,
Do you know what happened to Shaun Ferrel's car? Seemed to blow alot of smoke all of a sudden.
See'ya:burnout:
O ring on dipstick tube and a slightly over filled sump.
Cheers
Ken
It's dirty cause you an old married man:p
See'ya:burnout:
nuff of the old whipper snapper.
Least I got all my points and no yellow. There is something to be said for appearing old and respectable when stopped:p
Cheers
Ken
    • Just as a thought, if it's in neutral, thats your drive line disconnect, not the clutch. Clutch slip at the dyno with pedal fully out, is actually adding a second disconnect. So it's not a clutch issue if you're in neutral. Just a bit of friction dragging the output around while in the air.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
