  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
which is why I can't work out why people try to make their GTST's into R copies or try to make them faster.
My saying is that if you want a faster car , buy one from the manufacturer. Usually works out cheaper in the long run.
Cheers
Ken
Originally posted by caminperth
ken - yea.. well maybe half of it is in my head - but i honestly think it has made a diff.... u don't think they are worth it?
I assume you are talking about the brace between the shock mounts under the bonnet and not the sway bars under the car.
Strut braces work if they are attached to the suspension ( ie Macpherson strut style. )
The lines are double wishbone and the mount you are attaching to is not a stressed member of the car.Also unless it is straight and substantially thick , it will flex anyway.
I think you would find if you did an MC type day with the bar on and off , the difference would be marginal.
But hey , it looks cool and I have em on my car ( cos they came with it )
Cheers
Ken
Cheers
Ken
ken - hmmm everything you say sounds right.. but it still seemed to make a difference... maybe it is all in my head... but as you said - they look cool.. hehehe :(
paul - springs will be on the cards definitely.. was talking to no_respect tonight when i picked up the brace - his is about the right height (only about an inch lower than mine) and he said that he still retained a firm but comfy ride... he also said they're pretty damn easy to fit?
Originally posted by rob77
Ken, any pics or details of mods at all?
Ahh let me think
ARC aircleaner box
Big gay ally wing
18x9 BBS
Momo wheel
Recaro drivers seat
1/2 cage ( not in atm )
cusco shocks all round
Nismo top and bottom rear arms
Nismo caster arms
HKS evc4
4 defi gauges
cusco 1.5 way super f**cking loud diff
ogura twin or triple super f**ing bitey clutch
Got some pics of the as arrived condition but need your email addy.
Cheers
Ken
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
