  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
niz, if ya have a yellow and don't go down before the expiration of the specific date on the sitcker, they send you a letter to hand in your number plates as the car is deemed illegal, trust me i learnt by experience luckily they extended my expiry date :(
adrian :P
Originally posted by rob77
Whens it get here ken? I'm keen to have a look and drive if possible? Or you can take me for a drive :(
Next week it will be back from Sydney.
Have 2 guys who have first dibs on it ( thanks lumpy ) but you can certainly have a look at it.
I have bought in 6 GTR's in 2 years and even the grade 3.5 's needed work and they were 92's and 93's.
Would be surprised if the 89's didn't need at least the same if not more. If they are mint examples they go for a lot more than 700,000 yen or so. Check the dealer prices and yahoo japan for a truer indication on the good ones.
Cheers
Ken
I paid 550,000 yen for my r33. It was dead stock when it got here and was listed as a grade 4. Apart from 1 pin dent, which I think happened on the way here, it was a grade 4 car. Since then and a few australian carparks later its got 1 more pin dent, a paint scrape (that should polish out with a cut and polish) and a small dent in the drivers side door. I think I paid a pretty high price for a 94 dead stock car, but the condition is excellent.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
