  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe well on the way home last night i thought "shit this is boring - i need to do this this n this to the car" Woke-up this morning and thought - why bother? if it will help me keep my license i might as well keep it as it is and just make it rice :) until i get my points back anyway ....... which isnt til next year!
