  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
That trust kit could be the same as mine, but I dont think it will be. Mines the top of the range that uses the factory holes, RSPL I think, tube and fin. From memory off trusts website its 115,000yen which is roughly $1600 given exchange rate. So its more than likely a slightly smaller core or a bar and plate.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
    • Continental have consistently beaten the absolute shit out of every other performance tyre in Wet/Damp/Cold conditions and give up a little bit of time (half a second at most) in the dry. Almost like it's engineered for German conditions or something. I'd def give those a try.
    • I refer you to this thread on PF, by someone who knows what he's doing. Paints a good picture of the humble AD09.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
