  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
rob:- the hks type s kit is on the taka kaira site for like 1600 delivered nengun gonna do it for $1300 :) so trust is more then likely exactly like yours :)
cam:- if ya wanna use original holes then ya probably better off getting trust kit i'm guessin we shall wait and see :D
off topic anyone wanna give me a day time job?
adrian :(
Paul
It wasnt the exhaust that was the problem on Sunday the limiter came into play on those straights.
Adrian
Yes i think brent is getting a Apexi contact. He is the one who is getting my exhaust in after i had problems with australian supplier.
Cam
Hope you got your socket set in the car now? No worries anytime.
adrian damn... are u selling drugs on the side? :) jk man
franks (r34) from NSW has the HKS kit not sure which model but his uses the stock piping too.. pics:
http://www.skylinesaustralia.com/forums/sh...5026#post105026
