  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hey there russ, rob, ken, anyone else...
Ken - I got enough backlash in my rear diff that I should get it attended too. Had the car on a hoist at a local performance shop the other night to check it out. I was told that it was prolly something to do with a spacer type thingo (sorry cant remember exactly) that would need to be replaced inside the diff where the tailshaft connects. I think it is compliments of a lack of experience launching the car from the one time I went to the drags.
Anyway - to cut a long story short - can you tell me where to go?
Yep can do but your wife has already done it for me...
Is the diff noisy?
The spacer thingy is probably the crush washer for the pinion bearing.
My advice is to just turn up the radio a bit louder. Removing , o/hauling and while it's apart , replace the clutch packs , carrier bearings , reset the preload etc then the figure will be in the $1300- $1500 region.
Get a 2nd hand one and be ready to throw it in if you run out of radio volume.
Cheers
Ken
Originally posted by rob77
My driveshaft needed 3 new unijoints when it got here, they were all fubar'd and made the car vibrate. Place in osborne park machined them and replaced them for around $360 all up. Driveshaft Balancing I think the name was.
One of the few places I know is Diff and Trans in Jolimont.
Know a few tailshaft mobs but they are not diff rebuilders.
Cheers
Ken
Thanks guys.
Ken, there's no noise, & I think it was the crush washer that they were talking about. I wouldn't care about it except that I was told it could cause excessive wear on the crown wheel (I think that's what it's called).
But then again - drive it till it breaks then get one 2nd hand for around $500 bucks I reckon.
Originally posted by Micko
Thanks guys.
Zachary...
You one smart cookie boy:D
Cheers
Ken
Ken - I'm gonna check out Gav's mines ecu on sunday & will prolly be doing a deal with him. He reckons it gave him around 300rwhp on SST's dyno.
In conjunction with what.
Std they are around 200-220 hp at all 4 . Would be surprised if just a puter made that diff.
Cheers
Ken
Originally posted by 33Spec2
haha so true ken!:D where paul and aidwin these days? and they call themselves whores!!
Paul and Aidwin , both MIA.
ewww , that conjures up some horrible images.
No Niz either. Hmmm , a 3 some.....
Cheers
Ken
Let me know if you stumble across a diff in your travels Ken - if you see one for the right price it would be worth me buying for when either of us have a need for one :D
I gotta spare , it's in the ricer.:D
Actually ,C Red have a few for around the $800 mark and I think they may even have a 1.5 or 2 way.
Cheers
Ken
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
