The best thing to do is find out who the OIC is for all the divisions in perth. May seem like pointless name dropping but it helps if u are speaking with a cop set to make an example.
"hello officer......i actually let Snr Const balh balh know of this event just for safetys sake, we are on ure turf after all blah blah, fluff fluff"
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Yeh but u dont need to actually do it. Thats what im saying.
U just find out the name so u can drop it but dont speak to the OIC and say "hello if ud like to bust some ricers we will be here at this time and this is our map" its been done b4 and it never turns out well.
Thats why maps are no longer public like they used to be. Too much heat on the forums now days
Originally posted by Nizmo
well when u come back from a cruise bearing your yellow stickers and bitching about getting your car over the pits - there will be noooo sympathy from me - you were asking for it!
for the last f*kin time, read what i'm talking about...
I'm NOT talking about giving them maps.. I AM talking about discussing cruises in general with them to find out their opinions on them and to find out how to organise better ones that don't attract attention and therefore cause us no grief...
GET IT????!!
:D
i think hes getting antsy :D
Cops arent gonna tell us how to beat them. Overall its best to just go about our business and keep them out of it. U play the game every time u are on the road. Another excellent tool is a scanner. We avoided a fair bit of police attentin with one of those a fw cruises back. Apparently someone heard they were trying to set up a block for us at captain munchies.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
