  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
cam yeah i'm trying to see if i can get up there for wednesday should be able to
and cam two chicks in a bath reasonable quality
What's this , you gonna watch porn or make porn Troy ??
ohh and evening
Cheers
Ken
Originally posted by caminperth
LOL.. thats ok mate.. when will i need to fix him up for it?
Won't be a prob with paying till quite late cos the day is already organised. You would just be extra.
Cheers
Ken
