  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Dont you guys like my taste in music or something?
You must be jealous of my vocal skills:bahaha:
Nothing wrong with the Boss and the Eagles.
Just your rendition of the songs leaves a bit to be desired I am told.:D
Cheers
Ken
Originally posted by 33Spec2
hello niz
aaaaw the picture is gone!:D
vicki its russell lets see if you remember next time i ask you:D
Russell , you must have been the only one to see it.
Bloody too quick these mod guys...
Cheers
Ken
Fair enough - I am a shocking singer - only did it to entertain the crowd...
Hey Ken - ever since I changed the front pipes the fuel consumption has gone through the roof. Is this due to the bit of extra boost being made or would it just be because my foot has been welded to the floor 'testing' the new pipes?
Originally posted by Nizmo
hi russ n micko
Know how u feel Kyles - if it wasnt for the money im earning i would be outta my job as well - just one too many lazy bitchy dickheads there
Found out a long time ago , money isn't everything and lifes too short to be doing shit you don't like.
If you are prepared to have a go and not be afraid of the unknown , then quit .
Cheers
Ken
prolly the latter.
Have you got the mines puter in ?
Cheers
Ken
its just not nice going to work atm, I got a written warning today for some things i didnt even do. And I have to take some time off coming up beacuse of medical stuff and she was really unreasoable and really not understanding or supportive at all... And everyone else seems to have no problems getting time off for medical appiotments or things like that atm .. but im made to feel bad about it when i ask. Not my fault.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
