  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Micko
Niz - thanks for giving me the opportunity to get naomi to socialise with you all - helps give me more time to play cars the more she gets involved:D
No worries Micko , I'm sure we can keep your wife amused while you play cars....:D
Cheers
Ken
no probs Micko - glad u both had a good time :) hope me and my friends didnt scare her :D
Ken my last job was 19K and i was miserable in that the 35K makes a job so much more bearable - its not sooo mucht he job but the environment - hehe but revenge is mine - my supervisor was told he had to go down from a level 6 to a level 2 - the same level as me hehe - actually as of june 30 they pretty much have all new staff in that place - that will probably count me as gone as well
Yep Ken, got the mines ecu in. Was using the stocker before that though.
Should have the car on the dyno Wed night if steve can fit me in so we can see what the a/f ratio is like.
Car goes pretty good now methinks. Worth having the aftermarket dial in the car now;)
In that case , theres the problem. I would say the fuel ratio will be a bit rich as the japs like a lot of fuel and timing.
Cheers
Ken
I owned 2 businesses ( wrecking and Driver Training )
Made some SERIOUS money but the satisfaction wasn't there after a while.
Am working in a mates shop on the tools earning less than you but am happy , no stress, no employees , no aggro.
Life is good atm and I enjoy my time talking about cars again with people who like them for what they are and not a source of making money out of.
Cheers
Ken
did the guy withthe black skyline that liz is interested in end up ringing u today ken?
yep looked at it when he finally came to work at 5pm.
I won't steal liz's glory except to say she prolly won't be looking much any more.
Cheers
Ken
Cheers
Ken
good for u ken :D
brave wish i could be like that but atm i need the money and not really sure if i want to do anything else maybe if work was more demanding of my time and not so boring i would feel different.
but you've made money ken :D if it wasnt for that u wouldnt have the lifestyle and the ability to downgrade the job.
I havent made any money really - havent been able to acquire investments but when i get older i'll probably be able to do the same but for now its boring old work for me.
